[gdal-dev] GPKG to PostgreSQL, version 2.2.3 vs version 3.0.2
Ari Jolma
ari.jolma at gmail.com
Thu Apr 9 23:54:37 PDT 2020
Ari Jolma kirjoitti 9.4.2020 klo 17.23:
> Same outcome.
> There's something very strage going on as the max of the id is 305926
> (after creating the table with the first gpkg) but when I try to
> manually insert a row to the table it says "key id=39 already exists".
> If I then manually setval the sequence to 305926 I can add to the table.
> So somehow the sequence is lagging behind.
This seems to be the case. v 3.0.2 sends
SELECT setval(pg_get_serial_sequence('"stand"', 'id'), MAX("id") FROM
"stand";
and similar for other tables but v 2.2.3 does not.
Ari
> Ari
> jratike80 kirjoitti 9.4.2020 klo 16.14:
>> Hi,
>> I would have a try with -unsetfid. That should be the default when in
>> append
>> mode but the test is easy.
>> -Jukka Rahkonen-
>> Ari Jolma-2 wrote
>>> I have this command
>>> ogr2ogr -update -append -f PostgreSQL PG:... merged.gpkg
>>> which works ok in version 3.0.2 (self-compiled) but not in 2.2.3 (from
>>> ubuntu apt). The error is
>>> ERROR: duplicate key value violates unique constraint "stand_pkey"
>>> DETAIL: Key (id)=(1) already exists.
>>> CONTEXT: COPY stand, line 1
>>> STATEMENT: COPY "stand" ("wkb_geometry", "standid", "parcelid",
>>> "realestateid", "standnumber", "standnumberextension", "maingroup",
>>> "subgroup", "fertilityclass", "soiltype", "drainagestate",
>>> "ditchingyear", "thinningyear", "developmentclass", "standquality",
>>> "maintreespecies", "accessibility", "standinfo", "datasource",
>>> "growthplacedatasource", "area", "areadecrease", "creationtime",
>>> "updatetime") FROM STDIN;
>>> The issue is that "stand_pkey" is "CONSTRAINT stand_pkey PRIMARY KEY
>>> (id)" made by the
>>> ogr2ogr -overwrite -f PostgreSQL PG:... merged.gpkg
>>> earlier. So it shouldn't be in the COPY data at all (the log does not
>>> show whether it is there) or there is something wrong with the
>>> sequence.
>>> Is there a way to make it work in the older version?
>>> Ari
>>> gdal-dev mailing list
>>> gdal-dev at .osgeo
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
>> gdal-dev at lists.osgeo.org
