[gdal-dev] Windows CI build times
Jeff McKenna jmckenna at gatewaygeomatics.com
Fri Apr 17 06:50:54 PDT 2020
Hi Even,
I would vote for removing the VS2015 testing.
-jeff
On 2020-04-16 8:16 p.m., Even Rouault wrote:
> Hi,
> I've been a bit frustrated lately by the time spent on the GDAL AppVeyor
> CI builds: roughly 50 minutes for each of the two configs we test, VS
> 2017 x86 and VS 2015 x64, which can cause huge delays in case of busy
> days with many pull requests etc. (those delays also impact PROJ since
> the limitation to one simultaneous build is for the whole OSGeo GitHub
> organization)
> The immediate solution would be to just test VS 2017 x64 to cut that
> time down and drop VS2015 and x64 testing. However as strange as it
> sounds, there are still people using x86 builds...
> I guess porting to Azure Pipelines (which we already use to refresh
> gdal.org) could be a solution as well, since apparently they have a 10
> concurrent job limit ( according to
> https://docs.microsoft.com/en-us/azure/devops/pipelines/licensing/concurrent-jobs?view=azure-devops
> A ccache type of builds could also help since we rarely change headers.
> I believe I tried to investigate that in the past but didn't find
> anything really working.
> If someone is looking for ideas for contribution...
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
