[gdal-dev] Interpolation used for egm96_15.gtx when using RPC_DEM_APPLY_VDATUM_SHIFT
Yann-Sebastien Tremblay-Johnston yanns.tremblay at gmail.com
Fri Apr 17 09:53:34 PDT 2020
I spent a bit of time learning about vertical datum shifts when performing
RPC coordinate transformations using a DEM this week, and I was curious
about how the egm96_15.gtx file is interpolated. I was able to find in
gdal_rpc.cpp that the required vdatum shift is calculated using an OGR
Coordinate Transformation between the DEM spatial reference and a wgs84
ellipsoid spatial reference, but I’m not familiar enough with OGR/PROJ to
understand exactly how the gtx file is sampled.
Would anyone be able to shed a bit of light on this or point me in the
right direction?
Cheers,
Sebastien
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200417/f2a6f02f/attachment-0001.html>
