[gdal-dev] gdalwarp and gdaltransform are inconsistent
Pillio Zoltan
zoltanpillio at gmail.com
Sun Apr 19 12:21:12 PDT 2020
I'm new here, and just started using gdal, so maybe I'm misunderstanding
something, but I found that gdalwarp and gdaltransform produces different
results.
The gdaltransform command is :
echo 2600000 1196000 768 | gdaltransform -t_srs EPSG:4326 -s_srs EPSG:2056
and the result is:
7.43863317174838 46.9151021335816 817.714334204793
,but if I'm converting a geotif with the following command:
gdalwarp -t_srs EPSG:4326 -s_srs EPSG:2056
SWISSALTI3D_10_TIFF_CHLV95_LN02_2600_1196.tif test.tif
the height doesn't change. I'm using swisstopo example data from here:
https://cms.geo.admin.ch/Topo/swissalti3d/swissalti3dgeotifflv95.zip
I did the conversion by myself based on swisstopo documentation (link
above), and the result of gdaltransform is correct, but gdalwarp is wrong.
Do I misunderstand something, or did I make a mistake?
I'm using GDAL 2.4.2, released 2019/06/28
Thank you in advance for your help.
Best regards,
Zoltan Pillio
ps.:
I also found that setting height reference frame has no effect in these
cases:
EPSG:2056+5728
EPSG:2056+5729
and the swisstopo documentation for conversion I used:
https://www.swisstopo.admin.ch/content/swisstopo-internet/en/online/calculation-services/_jcr_content/contentPar/tabs/items/documents_publicatio/tabPar/downloadlist/downloadItems/19_1467104393233.download/ch1903wgs84_e.pdf
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200419/b76f1a5d/attachment.html>
