[gdal-dev] gdal_translate (3.1.0dev) "never" finishes on large jpeg cogs... REALLLLLY long time to unload.
Even Rouault even.rouault at spatialys.com
Tue Apr 21 13:10:52 PDT 2020
Andrew,
> When I create a mask band in a large lzw-compressed or jpeg-compressed tif
> using the COG driver it dramatically increases processing time over writing
> RGBA (hours instead of minutes), so the issue is not jpeg compression, it's
> the creation of the mask band. Steps to reproduce:
There's clearly some complications & overhead internally to be able to deal with non-alpha
mask bands. I wouldn't have expected it to be as large as you observed though. Would
require deeper investigation to understand why that causes such performance difference.
By the way, you can drop ---config GDAL_TIFF_INTERNAL_MASK YES when using the COG
driver. It sets it automacally.
> I also noticed that the -co BIGTIFF=NO option appears to be ignored in the
> COG driver. I can share a file if that's helpful (can not provide a link on
> the listserv)
I can't reproduce that:
gdal_translate byte.tif out.tif -of cog -co bigtiff=yes : creates a bigtiff file
gdal_translate byte.tif out.tif -of cog -co bigtiff=no -outsize 80000 80000 -co overviews=none
fails with "The TIFF file will be larger than 4GB, so BigTIFF is necessary.  Creation failed."
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200421/82a440b4/attachment-0001.html>
