[gdal-dev] NetCDF rotated grid support
    Even Rouault
    even.rouault at spatialys.com
    Thu Apr 23 11:45:51 PDT 2020
Louis-Philippe,
> I did some more tests with the rotated_pole.nc in gdal GitHub repo
> (https://github.com/OSGeo/gdal/tree/master/autotest/gdrivers/data) just to
> make sure the issue was not with my data.
> With the new versions, the EXTENSION is missing from the WKT, which I guess
> makes the reprojection fail when I try to view it in Qgis ?
Kind of... I confirm the issue. A complex interaction between GDAL and PROJ due to the
netCDF driver using a non-standard way of expressing a rotated pole CRS.
Well, there isn't really a standardized way, but what I did for GRIB2 recently was more in the
right direction (hopefully!)
So to address the issue, I've done 2 things:
- a fix for GDAL (in time for 3.1.0): https://github.com/OSGeo/gdal/pull/2438
- and one for PROJ: https://github.com/OSGeo/PROJ/pull/2185
The GDAL fix should probably be sufficient without the PROJ one, but I won't bet too much
on that...
Ultimately the netCDF driver should be improved similarly to the GRIB one, that is creating a
DERIVINGCONVERSION["Pole rotation (netCDF convention)"] instead of a hack.
So with both I now get with gdalinfo:
Coordinate System is:
GEOGCRS["unnamed",
    BASEGEOGCRS["unknown",
        DATUM["unknown",
            ELLIPSOID["unknown",6367470,0,
                LENGTHUNIT["metre",1,
                    ID["EPSG",9001]]]],
        PRIMEM["Greenwich",0,
            ANGLEUNIT["degree",0.0174532925199433],
            ID["EPSG",8901]]],
    DERIVINGCONVERSION["unknown",
        METHOD["PROJ ob_tran o_proj=longlat"],
        PARAMETER["lon_0",18,
            ANGLEUNIT["degree",0.0174532925199433,
                ID["EPSG",9122]]],
        PARAMETER["o_lon_p",0,
                ID["EPSG",9122]]],
        PARAMETER["o_lat_p",39.25,
                ID["EPSG",9122]]]],
    CS[ellipsoidal,2],
        AXIS["longitude",east,
            ORDER[1],
                ID["EPSG",9122]]],
        AXIS["latitude",north,
            ORDER[2],
                ID["EPSG",9122]]]]
Upper Left  ( -35.4700000,  23.6500003) ( 55d 6'46.50"W, 56d15'18.83"N)
Lower Left  ( -35.4700000, -23.8699996) ( 16d 4'19.39"W, 18d42'19.70"N)
Upper Right (  24.8100002,  23.6500003) ( 78d43'49.95"E, 63d51'22.90"N)
Lower Right (  24.8100002, -23.8699996) ( 42d35'19.21"E, 22d45'11.78"N)
Center      (  -5.3299999,  -0.1099997) (  9d37'52.99"E, 50d20'18.47"N)
The corner transformed in (non-rotated) geographic coordinates are now the same as GDAL
2.4, whereas before the fix, they were centered close to (0,0) as you mentionned.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200423/5ee11b02/attachment.html>
