[gdal-dev] Building for Java on MacOS
David Rush
david.rush at wyo.gov
Mon Apr 27 12:26:51 PDT 2020
Andrew:
That's what I thought. I do have the JDK (OpenJDK 11.0.2).
Ah, found it. I think I may have both a JRE and JVM confusing things
(confusing me, at least). Both appear to be the same version, at least.
I've changed my JAVA_HOME in java.opt to reflect where my JDK is
installed. Also had to change the JAVA_INCLUDE in java.opt because jni.h
is under $JAVA_HOME/include rather than $JAVA_HOME/Headers.
Then it couldn't find "jni_md.h" (machine dependent things, apparently). I
found it in my JDK installation, and copied it to the current directory
(gdal/swig/java), but it still can't seem to find it:
In file included from gdalconst_wrap.c:154:
/Library/Java/JavaVirtualMachines/jdk-11.0.2.jdk/Contents/Home/include/jni.h:45:10:
fatal error: 'jni_md.h' file not found
#include "jni_md.h"
Since the include is in quotes, it should be looking in the current
directory for it, right? The gdalconst_wrap.c file is in the current
directory, so I'm in the right place.
Suggestions?
David
On Mon, Apr 27, 2020 at 11:52 AM Andrew C Aitchison <andrew at aitchison.me.uk>
wrote:
> On Mon, 27 Apr 2020, David Rush wrote:
> > Ivan:
> > Thanks! That worked. On to the next error (with make in gdal/swig/java)
> > gdalconst_wrap.c:154:10: fatal error: 'jni.h' file not found
> > #include <jni.h>
> > 1 error generated.
> > make: *** [gdalconst_wrap.lo] Error 1
> > Where *should* jni.h come from? I can't find it anywhere in my Java
> > installation.
> I believe it should be in the JDK (Java Development Kit)
> - do you just have the JRE or Java Runtime Environment ?
> Andrew C. Aitchison Kendal, UK
E-Mail to and from me, in connection with the transaction
of public
business, is subject to the Wyoming Public Records
Act and may be
disclosed to third parties.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200427/b06a7900/attachment.html>
