[gdal-dev] GDAL memory management
Jesús
knoonk at gmail.com
Thu Apr 30 04:27:01 PDT 2020
Thanks for your answer, Even.
I would want that, yes, but I was prepared for the answer being no :(.
I also though computational complexity would be the problem, but I checked
with VTune and it points the other way (malloc, free, realloc). Moreover,
performance is worse each time I execute the same test in the same run, so
I think that would match some memory fragmentation or something like that.
Thanks again,
Jesús Cano
El jue., 30 abr. 2020 a las 11:24, Even Rouault (<even.rouault at spatialys.com>)
escribió:
> Jesús,
> > I have been working with C/C++ and GDAL with GEOS for some time now and I
> > have a question about GDAL memory management.
> > I wonder if there are any memory management options or tips to control
> > allocations and deallocations in the library since we are noticing
> > performance problems as our data increases in complexity, mainly OGR
> > operations (intersection, simplify).
> > For example, I would expect something to do the same as:
> > - std::allocator: http://www.cplusplus.com/reference/memory/allocator/
> > - CGAL allocator:
> > https://doc.cgal.org/latest/Manual/devman_memory_management.html
> > - SQLite memory allocation routines:
> > https://www.sqlite.org/c3ref/mem_methods.html
> > I have been looking for it, but GDAL is so big that maybe I missed
> > something.
> Interaction between GDAL and GEOS is in ogr/ogrgeometry.cpp and
> ogr/ogrgeometryfactory.cpp
> Basically GDAL will export geometries to WKB and GEOS will instanciate its
> geometry object from it. The temporary WKB buffer created by GDAL is using
> CPLMalloc() that is just a wrapper over malloc().
> GEOS will likely use standard C++ memory operators (new, vector) etc.
> And ultimately GDAL will reconstruct a OGR Geometry from a GEOS WKB
> buffer, using a mix of C++ new and CPLMalloc
> From the links you refering, it seems you'd want a way to use your own
> memory management routines. There's no such possibility in GDAL.
> CPLMalloc()/CPLRealloc()/CPLFree() could possibly be redirected to some
> callbacks. On the C++ side, not sure what would be involved.
> Are you really sure that the bottleneck you see are in memory
> allocations/deallocations themselves ? I'd expect more computational
> complexity to be the main limit.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200430/22cea0f8/attachment.html>
