[gdal-dev] Query regarding using gdalwarp with cutlineSQL
CainĂ£ K. Campos rupestre.campos at gmail.com
Sat Aug 1 04:58:35 PDT 2020
I believe that you should use either the cutlineWhere or the cutlineSQL.
When I want a single field selection, I use the cutlineWhere,
when it is more complex I use the cutlineSQL
On Fri, Jul 31, 2020 at 6:40 PM Luke <lukepinnerau at gmail.com> wrote:
> You need  single quotes around your string literal:
> cutlineWhere="name = 'first'"
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200801/734fa302/attachment.html>
