[gdal-dev] GetSpatialRef, OGRSpatialReference and memory leaks ?
Even Rouault
even.rouault at spatialys.com
Mon Aug 3 03:01:45 PDT 2020
On samedi 1 août 2020 10:44:45 CEST Andrew C Aitchison wrote:
> I would like to define GetSpatialRef() for my raster driver as something
> like:
> const OGRSpatialReference* GetSpatialRef() const override {
> OGRSpatialReference* poSRS = new OGRSpatialReference();
> if (poSRS->importFromEPSGA(27700)!=OGRERR_NONE)
> delete poSRS;
> poSRS = nullptr;
> return poSRS;
> Unfortunately, valgrid reports that this leaks in the "new"
> on the line
> On the other hand,
> return new OGRSpatialReference("EPSG:27700");
Andrew,
You should hold a OGRSpatialReference object as a member variable of the dataset object
and return its address. The ownership of the object remains to the dataset object as
indicated in the doc:
* \brief Fetch the spatial reference for this dataset.
* Same as the C function GDALGetSpatialRef().
* When a projection definition is not available, null is returned
* @since GDAL 3.0
* @return a pointer to an internal object. It should not be altered or freed.
* Its lifetime will be the one of the dataset object, or until the next
* call to this method.
* @see http://www.gdal.org/osr_tutorial.html
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200803/c150aad2/attachment.html>
