[gdal-dev] Extracting a band with gdalmdimtranslate
Joe Lee
hyoklee at hdfgroup.org
Fri Aug 7 21:55:41 PDT 2020
Please try
$ gdalmdimtranslate -array "name=/swaths/mod35/Data Fields/Quality_Assurance,transpose=[2,1,0]" MOD35_L2.A2017161.1525.061.2017315035809.hdf test.tif
as shown in [1], which I updated it today for MOD35_L2.
[1] https://github.com/hdfeos/zoo/tree/master/gdal
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of J. Antonio Guzmán Q.
Sent: Friday, August 07, 2020 4:44 PM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Extracting a band with gdalmdimtranslate
I am trying to extract a band (byte 3) from the Quality_Assurance SDS of MODIS Cloud Mask swath product (MOD35-MYD35). Overall, I can not extract a band or array using gdalwarp since the dimensions of the array seems to be [Along, Across, Bytes] [2040x1354x10] and not [Bytes, Along, Across]. Therefore, I am trying to use gdalmdimtranslate to first transpose the array (transpose=[2,0,1]) and then do the extraction as GTiff.
Despite this, I am not totally sure about code writing or logic for this; maybe some of you can help me.
My code is the following for the enclosed file below
gdalmdimtranslate HDF4_EOS:EOS_SWATH:MOD35_L2.A2017161.1525.061.2017315035809.hdf:mod35:Quality_Assurance example.tif -scaleaxes 'QA_Dimension:mod35(3)'
I am running this from the cmd as a test using gdal 3.1.1. I always get an ERROR 5:
GDALDataset::GetRasterBand(-1) - Illegal band
I also try to call the dimension in different ways out results. If you have a different approach to extract the Byte 3 of this SDS that is also welcome.
I also enclosed a .txt as a results of gdalinfo
Best regards,
https://drive.google.com/file/d/1fMZrfMLl18e_D6CjJbscwhLvoFFGORJp/view?usp=sharing
https://drive.google.com/file/d/1f7oda-N9YT_cyf7YRw80BNQZr2O0RUMe/view?usp=sharing
_______________________
J. Antonio Guzmán Q., M.Sc
Ph.D Candidate and Vanier Scholar
Earth and Atmospheric Sciences Department
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200808/4251534b/attachment-0001.html>
