[gdal-dev] Reading a JP2 file - obj_decode() failed
Even Rouault
even.rouault at spatialys.com
Sun Aug 9 03:14:35 PDT 2020
Jonathan,
The GDAL build that comes with rasterio must have only JP2OpenJPEG enabled (the error
with opj_decode() comes from that driver), whereas the GDAL build in QGIS has also JP2ECW,
which is used in priority.
The file is large. It would be interesting to know if it is tiled. If you do "gdalinfo --format
FILENAME.jp2 --config GDAL_SKIP JP2ECW", and look at the beginning of the output, you
should see lines like
OPENJPEG: nTileW = XXXX
OPENJPEG: nTileH = XXXX
which values are reported ?
If it is tiled (values <= 2048 let's say), this should normally work. Openjpeg will have more
difficulties with single-tile JPEG2000 files, although latest versions (2.3.1) have seen
improvements in that regard
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200809/3061157e/attachment.html>
