[gdal-dev] Reading a JP2 file - obj_decode() failed
Jonathan Moules jonathan-lists at lightpear.com
Sun Aug 9 12:34:28 PDT 2020
I guess this is what you want:
         <Field name="XTsiz" type="uint32">132000</Field>
         <Field name="YTsiz" type="uint32">248000</Field>
Which I'm assuming means it's not tile.
On 2020-08-09 15:46, Even Rouault wrote:
> On dimanche 9 août 2020 15:30:12 CEST Jonathan Moules wrote:
> > Hi Even,
> > Ah, it's comma delimited. I tried spaces.
> > Here's the response, with with light editing to get rid of duplicate
> > info (The bands are all the same). Nothing in the output with the string
> > "tile".
> Ah, sorry, I now see those debug traces aren't compiled in in release
> mode.
> OK, so download
> https://github.com/OSGeo/gdal/blob/master/gdal/swig/python/samples/dump_jp2.py
> and run
> python dump_jp2.py FILENAME.jp2 | grep Tsiz
> Spatialys - Geospatial professional services
> http://www.spatialys.com
