[gdal-dev] Rotation not found from ENVI header
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Mon Aug 17 14:10:17 PDT 2020
No, it was not a manual try. GDAL, before your fix, creates a .hdr file that shows rotation=90 with command
gdal_translate -ot UInt16 -scale -of ENVI -outsize 1025 1025 dgm1_32372_5680_2_nw.tif dgm1_32372_5680_2_nw.raw
-Jukka-
Lähettäjä: Even Rouault <even.rouault at spatialys.com>
Lähetetty: maanantai 17. elokuuta 2020 23.53
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
Kopio: gdal-dev at lists.osgeo.org
Aihe: Re: [gdal-dev] Rotation not found from ENVI header
On lundi 17 août 2020 20:44:35 CEST Rahkonen Jukka (MML) wrote:
> Hi,
> In the question at gis.stackexchange the rotation was 90 but I trust that
> the issue is the same.
The mention of 90 in the stackexchange thread is confusing. I think it is a manual try, but the original GeoTIFF used for convertion, and which triggered the error message, has a positive value for the y-res / south-up orientation, so a 180 deg rotation
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200817/ab435041/attachment-0001.html>
