[gdal-dev] I have a problem getting higher resolution in a VRT file
Stephen Woodbridge
stephenwoodbridge37 at gmail.com
Wed Aug 19 15:41:51 PDT 2020
Hi all,
I've been puzzling over a problem with trying to get a higher resolution
images using a VRT file so low res data looks smoother in mapserver.
This is my source tif image:
gdalinfo /maps/wms/data/HYCOM/HYCOM_today_mlt.tif
Driver: GTiff/GeoTIFF
Files: /maps/wms/data/HYCOM/HYCOM_today_mlt.tif
Size is 4500, 4251
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (-180.000000000000000,90.000000000000000)
Pixel Size = (0.080000000000000,-0.040000000000000)
Metadata:
AREA_OR_POINT=Area
[snip more metadata]
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left (-180.0000000, 90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"N)
Lower Left (-180.0000000, -80.0400000) (180d 0' 0.00"W, 80d 2'24.00"S)
Upper Right ( 180.0000000, 90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"N)
Lower Right ( 180.0000000, -80.0400000) (180d 0' 0.00"E, 80d 2'24.00"S)
Center ( 0.0000000, 4.9800000) ( 0d 0' 0.01"E, 4d58'48.00"N)
Band 1 Block=4500x1 Type=Float32, ColorInterp=Gray
NoData Value=1.2676506002282294e+30
Overviews: 2250x2126, 1125x1063, 563x532, 282x266, 141x133, 71x67
I generate a VRT file as part of my processing and add a color table and
increase the resolution. It looks like this:
gdalinfo /maps/wms/data/HYCOM/HYCOM_today_mlt.vrt
Driver: VRT/Virtual Raster
Files: /maps/wms/data/HYCOM/HYCOM_today_mlt.vrt
Size is 72000, 68016
GEOGCS["WGS 84",
DATUM["WGS_1984",
Pixel Size = (0.005000000000000,-0.002500000000000)
Corner Coordinates:
Band 1 Block=128x128 Type=Byte, ColorInterp=Palette
Overviews: 36000x34016, 18000x17008, 9008x8512, 4512x4256, 2256x2128,
1136x1072
Color Table (RGB with 256 entries)
[snip color table]
And in my mapfile I have a layer defined like:
LAYER
NAME "mlt"
STATUS ON
TYPE RASTER
PROJECTION "init=epsg:4326" END
DATA "/maps/wms/data/HYCOM/HYCOM_today_mlt.vrt"
PROCESSING "NODATA=1.2676506002282294e+30"
PROCESSING "SCALE=0,250"
END
This all seems like it should be working correctly, but in my OL app,
the resolution is not changing. I would expect the with the higher
resolution I would see smoother color transitions as I zoom in on the
image and that the pixel blocks would appear smaller. Unfortunately, I'm
not seeing a difference.
So I assume I've done something wrong somewhere, but I'm not see what :(
Any Ideas?
Thanks,
-Steve
Oh and the VRT file looks like this:
<VRTDataset rasterXSize="72000" rasterYSize="68016">
<SRS>GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4326"]]</SRS>
<GeoTransform> -180.0 ,0.005 , 0 , 90.0 , 0 , -0.0025 </GeoTransform>
<Metadata>
</Metadata>
<VRTRasterBand dataType="Byte" band="1">
<ColorInterp>Palette</ColorInterp>
<ColorTable>
<Entry c1="0" c2="0" c3="0" c4="255"/>
[snip color table entries]
<Entry c1="255" c2="255" c3="255" c4="255"/>
</ColorTable>
<SimpleSource resample="bilinear">
<SourceFilename
relativeToVRT="1">HYCOM_today_mlt.tif</SourceFilename>
<SourceBand>1</SourceBand>
<SourceProperties RasterXSize="4500" RasterYSize="4251"
DataType="Float32" BlockXSize="4500" BlockYSize="1" />
<SrcRect xOff="0" yOff="0" xSize="4500" ySize="4251"/>
<DstRect xOff="0" yOff="0" xSize="72000" ySize="68016"/>
</SimpleSource>
</VRTRasterBand>
</VRTDataset>
