[gdal-dev] I have a problem getting higher resolution in a VRT file
Chang Liao
changliao.climate at gmail.com
Sat Aug 22 22:07:55 PDT 2020
Has anyone looked into the so called regrid in Earth system model? How is
it different from GIS resampling?
Grid Remapping
ESMF has the option to build a standalone application, called *RegridWeightGen
<http://www.earthsystemcog.org/projects/regridweightgen>*, that can
generate interpolation weights in parallel. It's fast and can handle a wide
variety of grids and grid options. It's not necessary to use the rest of
ESMF to use it ... just provide grid files in a standard (netCDF-based)
format.
https://www.earthsystemcog.org/projects/esmf/
Thanks.
On Thu, Aug 20, 2020 at 8:40 AM Stephen Woodbridge <
stephenwoodbridge37 at gmail.com> wrote:
> Jukka,
> Thanks those are great threads and very educational.
> I solved my problem. I was using upsample="bilinear" rather than
> upsampling="bilinear" and fixing this gave the expected results. But if
> not for my stupid typo, I would not have had a chance to read those
> threads and google others regarding upsampling.
> Thanks for the assist,
> -Steve
> On 8/20/2020 10:13 AM, Rahkonen Jukka (MML) wrote:
> > Hi,
> > Resampling is science that would be nice to understand. Unfortunately I
> don't but I think that this thread is worth reading
> osgeo-org.1560.x6.nabble.com/gdal-dev-downsampling-geotiff-with-a-low-pass-filter-td5385890.html.
> In this gis.SE question cubic spline was considered good
> https://gis.stackexchange.com/questions/30627/smoothing-reinterpolating-raster-with-gdal
> > -Jukka-
> > -----Alkuperäinen viesti-----
> > Lähettäjä: Stephen Woodbridge <stephenwoodbridge37 at gmail.com>
> > Lähetetty: torstai 20. elokuuta 2020 16.58
> > Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi
> > Aihe: Re: [gdal-dev] I have a problem getting higher resolution in a VRT
> file
> > Hi Jukka,
> > Any thoughts on what would be a better way to upsample and image using
> GDAL?
> > I assumed, maybe incorrectly, that if I’m up sampling between two pixels
> with values of say 1 and 2 that a new pixel 50% between them would get a
> value of 1.5 and at 25% would get a value 1.25 etc. using linear
> interpolation and bilinear would also account for rows above and below the
> current row.
> > Even, I specified resampling=“bilinear” in the vrt file is this ignored?
> > Thanks, Steve
> > Sent from my iPhone
> >> On Aug 20, 2020, at 8:23 AM, jratike80 <
> jukka.rahkonen at maanmittauslaitos.fi> wrote:
> >> Even Rouault-2 wrote
> >>> By default, VRT uses nearest resampling. You must specify something
> else.
> >>> Look for "A resampling attribute can be specified" in
> >>> https://gdal.org/drivers/raster/vrt.html
> >> Actually in the provided .vrt file I can see <SimpleSource
> >> resample="bilinear">
> >> But isn't bilinear unsuitable for upsampling and some more blurring
> >> method might work better?
> >> -Jukka Rahkonen-
> >> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> >> _______________________________________________
> >> gdal-dev mailing list
> >> gdal-dev at lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Best Regards!
Chang Liao,PhD
Earth Scientist, Atmospheric Sciences & Global Change Division
Pacific Northwest National Laboratory, WA, USA.
Email: changliao.climate at gmail.com or chang.liao at pnnl.gov
Personal Website: http://www.changliao.us
Skype: changliao1025
Lab Website: www.pnnl.gov
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200822/59ebf0aa/attachment.html>
