[gdal-dev] Can a GepPDF be generated using a Composition file from command line?
Ian Mayo ian at planetmayo.com
Wed Aug 26 05:40:30 PDT 2020
The documentation page for PDF via GDAL includes the description for
using an XML Composition File:
https://gdal.org/drivers/raster/pdf.html#creation-of-pdf-file-from-a-xml-composition-file-gdal-3-0
But, the description only gives examples of the XML Composition file
being used from C++ or Python code.
Is it possible to use the XML Composition file directly from GDAL
commands on the command line?
(presumably the Composition file would be passed as a -co creation
option parameter)
Thanks,
Ian
