[gdal-dev] Wrong sliding when AREA_OR_POINT metadata is edited?
Even Rouault
even.rouault at spatialys.com
Wed Aug 26 14:24:40 PDT 2020
Jukka,
> It is late and I feel fuzzy but shouldn't the pixel_is_point variant has
> smaller easting, greater northing instead, thus (-180,0439453,
> 90,04394531)?
> The images are georeferenced with tiepoints/GCPs, perhaps it adds something
> to the soup?
I concur with your analysis. The compensation done by GDAL to report georeferencing in its
usual way is done in the wrong direction here. This is specific to tiepoints (geotransform case
is a different code path), and it appears that this wasn't tested in RFC33 implementation.
Pending fix per
https://github.com/OSGeo/gdal/pull/2892
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200826/e358bb8e/attachment.html>
