[gdal-dev] gdal_translate into netCDF file will lose some important metadata items such as scale_factor and add_offset
Zhan Li
zhanli1986 at gmail.com
Sun Aug 30 15:11:54 PDT 2020
Hi, when I use gdal_translate to convert a raster file (e.g., either GTiff
or VRT) into netCDF format, it always loses some important metadata items
such as scale_factor, add_offset and etc. What am I doing it wrong? Can
anyone help me to solve this problem?
Here I'm using an example NetCDF file from NOAA
<ftp://ftp.cdc.noaa.gov/Datasets/cmap/std/precip.mon.mean.nc> called "
precip.mon.mean.nc " to demo the problem.
First convert one band of the netCDF file into a GTiff file.
$ gdal_translate -of GTiff -b 1 precip.mon.mean.nc precip.mon.mean.b1.tif
$ gdalinfo precip.mon.mean.b1.tif
It returns the following 16 metadata items for the band in the following,
Band 1 Block=144x14 Type=Float32, ColorInterp=Gray
NoData Value=-9.96920996838686905e+36
Unit Type: mm/day
Metadata:
actual_range={0,59.080002}
add_offset=0
dataset=CPC Merged Analysis of Precipitation Standard
least_significant_digit=2
level_desc=Surface
long_name=Average Monthly Rate of Precipitation
missing_value=-9.96921e+36
NETCDF_DIM_time=1569072
NETCDF_VARNAME=precip
parent_stat=Mean
precision=2
scale_factor=1
statistic=Mean
units=mm/day
valid_range={0,70}
var_desc=Precipitation
Now convert the GTiff back into a netCDF file
$ gdal_translate -of netCDF precip.mon.mean.b1.tif precip.mon.mean.b1.nc
$ gdalinfo precip.mon.mean.b1.nc
Now it returns only 12 metadata items which miss some particular important
ones such as scale_factor, add_offset, and etc.
Band 1 Block=144x1 Type=Float32, ColorInterp=Undefined
Unit Type: mm/day
Metadata:
level_desc=Surface
parent_stat=Mean
precision=2
statistic=Mean
units=mm/day
_FillValue=-9.96921e+36
Thanks,
Zhan.
Zhan Li <https://zhanlilz.github.io/>, 李展;
Google Scholar
<https://scholar.google.com/citations?user=JGNL9BoAAAAJ&hl=en>,
ORCID <https://orcid.org/0000-0001-6307-5200>, Github
<https://github.com/zhanlilz>,
Twitter <https://twitter.com/zhanlilz>, LinkedIn
<https://www.linkedin.com/in/zhanli/>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200831/3efe75e9/attachment.html>
