[gdal-dev] Converting OBJ to Geojson files with ogr2ogr
Paul Harwood
runette at gmail.com
Wed Dec 2 02:31:34 PST 2020
.OBJ is a simple object mesh (or to put it in more traditional terms: TIN)
- it has shape but no data values and is not geolocated.
I don't think there is any driver for OGR that will read .OBJ.
You are going to problems with geolocation if you write your own. Geojson
requires that the geometries are geolocated - and in the current version
that they are in epsg:4326. That is not totally impossible - people have
been using .dxf files for gis data for decades and that format is also not
in theory geolocated. It is not a trivial problem though.
I guess I would ask the usual question .. why?
- what are you actually trying to achieve and why a GIS format like GeoJSON?
- If you have to use GeoJSON - I am guessing you are transferring some data
to something that reads GeoJSON only? In that case - can your source
produce .dxf? OGR can read .dxf.
- If you only have the source in .OBJ - what other formats can the
destination read? Although, if you only have the source in .obj, I very
much doubt any of the GIS tools like GDAL are going to be able to help you.
It just is not a format used in GIS.
It is a problem we solved in the ViRGiS projec <http://www.virgis.org>t -
since .obj is used a lot in VR. There we used an existing library to read
the .obj files - but that is in C# and I doubt that would help you.
On Tue, 1 Dec 2020 at 20:15, Andrew C Aitchison <andrew at aitchison.me.uk>
wrote:
> On Tue, 1 Dec 2020, Brandon Biggs wrote:
> > Hello,
> > I am wondering how to convert an obj file to a geojson file? I am using
> ogr2ogr with the command:
> > Ogr2ogr -f geojson output.geojson input.obj
> > But get the error that ogr2ogr does not have an OBJ driver. I looked on:
> > the vector drivers page<https://gdal.org/drivers/vector/index.html>
> > but am unable to find a simple obj converter. I am wondering if there is
> such a thing? I am probably going to write my own that does what I want,
> because OBJ is so simple, I was just wondering if GDAL could already do it.
> I've never heard of OBJ, but that doesn't mean much.
> If you only want a read-only ogr driver you might want to look at
> https://gdal.org/tutorials/vector_python_driver.html
> if you would find a quick-n-dirty python quicker to write than C++.
> Andrew C. Aitchison Kendal, UK
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201202/d2c60650/attachment.html>
