[gdal-dev] Sampling raster bands at irregular points
Felix
felix.divo at sailingteam.tu-darmstadt.de
Thu Dec 3 05:16:24 PST 2020
Hello All,
I'm here for some suggestions on how to sample from a raster band at
_non-regular_ points. Non-regular in this context means that the points
have arbitrary coordinates and do not lie on a regular lattice/mesh like
all pairs of integers would do.
In my application, there is an irregular set of points for which we
require bathymetric data (i.e. topographical data/elevation). I started
out by manually reading in the ETOPO1 dataset (for now, we might use
Earth2014 later) and then interpolating around each point sequentially.
As we have up to hundred-tousands of points and doing the computation
sequentially in Python/numpy, this is currently running for days (well,
we canceled it at that point).
Ideally, I'd like to use something like the "gdal_grid" tool, where the
interpolation algorithm can be configured and the heavy-lifting is done
in C rather than in Python. But it only supports creating a new
_regular_ grid. The inverse distance interpolation with cutoff radii
would be ideal.
Does such a tool/such functionality exist in in GDAL or was my search
rightfully fruitless? I mainly searched in the raster programs, the
(C++) API of GDALRasterBand and of course generally in the internet.
Thank you for your suggestions, in advance!
Cheers and Stay Safe
Felix Divo
