[gdal-dev] Querying RasterBands near edges
Andrew C Aitchison
andrew at aitchison.me.uk
Mon Dec 7 13:45:44 PST 2020
On Mon, 7 Dec 2020, Felix wrote:
> Our application requires us to fetch for many pairs of (latitude, longitude)
> all existing values within some radius from an existing raster dataset. Is it
> possible to read values from a GDALRasterBand given some general bounding
> box, even if it is at the edge of a dataset?
> One can easily convert between bounding boxes in geographical coordinates and
> pixels using Dataset::GetGeoTransform() and InvGeoTransform(), but
> GDALRasterBand/GDALMDArray/the Python bindings seems to not have a method for
> being queried by it. Of course, simple boxes can be read e.g. using the
> Python methods Band::ReadAsArray/Band::ReadRaster. But this does not work
> once queries get to the boundaries, as all of these methods do not support
> "wrapping around" to the other side of the dataset. As an example:
> Dataset: 1000 x 1000 pixels
> Bounding box in pixels, given as two corner points in (x, y) pixels:
> (950, 950) and (50, 50)
> This should query all 50 by 50 pixel corners of the dataset and
> result in a 100 by 100 pixel result
> It arises when a point at the edge of a dataset is queried with a
> radius of 50 pixels
> However, numpy and the above methods do not allow to express such
> wrap-around indexing
> Is there some method that I'm overlooking or is this intentionally something
> that users should implement for themselfs? It feels like such indexing would
> be required in a lot of other places too.
Unless your dataset covers the whole world, I don't understand why would
wld want such a wrap-around for a geographical application.
Even then you would wrap at the left/right border but not the poles
(top/bottom).
If you are processing whole world data, could you generate a second raster
with the left and right halves swapped and split the points into two sets ?
Then provided you use the correct image for each set your radius wont
cross the edge of the raster.
Andrew C. Aitchison Kendal, UK
