[gdal-dev] Problem with gdal. Warp 6257
Even Rouault even.rouault at spatialys.com
Tue Dec 8 14:14:47 PST 2020
On mardi 8 décembre 2020 23:03:54 CET Yrneh Ulloa-Torrealba wrote:
> Dear GDAL community,
> I had a problem using gdal.Warp for a raster from EPSG 6257 to 6686. Does
> someone know why this happened?
> More information on:
> https://gis.stackexchange.com/questions/380877/reprojection-with-gdal-warp-d
> oesnt-work
EPSG:6257 uses the "Colombia Urban" projection method, whose support has been
added only in PROJ 7.2 (
https://proj.org/operations/projections/col_urban.html )
And there must be an error in the target EPSG code in your post: EPSG:6686 is
a Japanese CRS (well, you could technically try to do the reprojection, but it
is unlikely this is what you want to do)
Even
http://www.spatialys.com
