[gdal-dev] promote_to_multi and python API
Norman Vine
nhv at meganet.net
Thu Dec 10 03:54:50 PST 2020
I usually peruse the ogr2ogr.py source for hints
maybe this helps
https://github.com/OSGeo/gdal/blob/master/gdal/swig/python/samples/ogr2ogr.py#L1512
> On Dec 10, 2020, at 3:39 AM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> is there a way to apply PROMOTE_TO_MULTI in Python API? I am trying to
> write a sample script for students in Python which converts SHP file
> to PostGIS layers. I am dealing with a well known problem "Geometry
> type (MultiXXX) does not match column type (XXX)".
> How to solve it properly in order to avoid calling `ogr2ogr` from
> Python code? :-)
> Thanks, Martin
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
