[gdal-dev] gdaljni
paul.malm at lfv.se paul.malm at lfv.se
Fri Dec 11 04:15:23 PST 2020
This java command: Dataset ds = gdal.Open(txtInFilename.getText());
Generates:
Exception in thread "AWT-EventQueue-0" java.lang.UnsatisfiedLinkError: org.gdal.gdal.gdalJNI.Open__SWIG_1(Ljava/lang/String;)J
            at org.gdal.gdal.gdalJNI.Open__SWIG_1(Native Method)
            at org.gdal.gdal.gdal.Open(gdal.java:589)
            at raster.ImageTiler.info(ImageTiler.java:233)
            at raster.ImageTiler.access$2(ImageTiler.java:230)
            at raster.ImageTiler$2.mouseReleased(ImageTiler.java:211)
            at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:290)
            at java.awt.Component.processMouseEvent(Component.java:6539)
            at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
            at java.awt.Component.processEvent(Component.java:6304)
            at java.awt.Container.processEvent(Container.java:2239)
            at java.awt.Component.dispatchEventImpl(Component.java:4889)
            at java.awt.Container.dispatchEventImpl(Container.java:2297)
            at java.awt.Component.dispatchEvent(Component.java:4711)
            at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)
            at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4535)
            at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)
            at java.awt.Container.dispatchEventImpl(Container.java:2283)
            at java.awt.Window.dispatchEventImpl(Window.java:2746)
            at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
            at java.awt.EventQueue.access$500(EventQueue.java:97)
            at java.awt.EventQueue$3.run(EventQueue.java:709)
            at java.awt.EventQueue$3.run(EventQueue.java:703)
            at java.security.AccessController.doPrivileged(Native Method)
            at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
            at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
            at java.awt.EventQueue$4.run(EventQueue.java:733)
            at java.awt.EventQueue$4.run(EventQueue.java:731)
            at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
            at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
            at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
            at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
            at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
            at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
            at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Anyone who knows what I have to do?
Kind regards,
Paul
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201211/575f4cc1/attachment-0001.html>
