[gdal-dev] Best way to read jpeg interleaved
Even Rouault
even.rouault at spatialys.com
Thu Dec 17 10:47:24 PST 2020
Javier,
> I want to read quickly a jpeg file, and store it in memory interleaved
> (RGBRGBRGB).
> Is this the fastest way to read it?
Yes. There is even an optimized code path in the JPEG driver for that
situation that short circuits completely the GDAL block cache.
> Regarding the parameter "nLineSpace", documentation says
> nLineSpace The byte offset from the start of one scanline in pData to the
> start of the next. If defaulted (0) the size of the datatype eBufType *
> nBufXSize is used.
> In the code above, if I set nLineSpace to 0, it works fine. However, if I
> write what documentation says ( 1 * width ), it does not work. Is this a
> bug in the documentation, or am I understanding it wrongly?
The relevant code is:
/* If pixel and line spacing are defaulted assign reasonable */
/* value assuming a packed buffer. */
if( nPixelSpace == 0 )
nPixelSpace = GDALGetDataTypeSizeBytes(eBufType);
if( nLineSpace == 0 )
nLineSpace = nPixelSpace * nBufXSize;
if( nBandSpace == 0 && nBandCount > 1 )
nBandSpace = nLineSpace * nBufYSize;
The doc is correct if all spacing parameters are set to 0, but indeed not if
you put some to 0 and others not. PR to make it more accurate welcome.
Even
http://www.spatialys.com
