[gdal-dev] Geotransform for non-North-up images?
Javier Jimenez Shaw
j1 at jimenezshaw.com
Mon Dec 21 07:02:48 PST 2020
I am not sure, but I guess that you have to negate also GT5: y axis is
reversed between image coordinates and "geographic" coordinates.
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Mon, 21 Dec 2020 at 14:57, G Seiffert <hh1 at posteo.de> wrote:
> Thanks Javier. Need to confess: math is not my strong side. I'm more the
> "trial and error" guy. And - shame on me - Google.
> Got the rotation AND the scaling correct meanwhile, calculating the params
> as described here:
> https://gis.stackexchange.com/questions/69715/rotating-rasters-using-gdal-geotransform-and-arcgis-desktop?noredirect=1&lq=1
> Below a code snippet (I work in Python). However, with the exact calcs
> from above website, my pics were rotated correctly but for some strange
> reason mirrored vertically! Try and error: Making GT(4) negative got rid of
> the mirroring. So almost happy now, just facing a weird shift of 2m to west
> and 0.7m to south, working on it.
> # ROTATION PART Start ================================================
> rot_deg = 90
> rotation = np.deg2rad(rot_deg)
> GT0 = orig_x
> GT1 = math.cos(rotation) * image_resolution
> GT2 = -math.sin(rotation) * image_resolution
> GT3 = orig_y
> GT4 = -math.sin(rotation) * image_resolution
> GT5 = math.cos(rotation) * image_resolution
> geotrans = (GT0, GT1, GT2, GT3, GT4, GT5)
> # ROTATION PART End ================================================
> Thanks so far! Also Thomas and Jukka!
> Gerhard
> Javier Jimenez Shaw <j1 at jimenezshaw.com>
> 21 December 2020 10:55
> Those transformation parameters can be seen as a 3x3 transformation matrix
> like this
> Xg GT1 GT2 GT0 Xp
> Yg = GT4 GT5 GT3 * Yp
> 1 0 0 1 1
> Where [Xp, Yp] is the coordinate in pixels, and [Xg, Yg] is the
> "geographic" coordinate (whatever it means ;)
> the 2x2 top left corner of the transformation matrix can be seen as a 2D
> rotation-scaling matrix:
> https://en.wikipedia.org/wiki/Transformation_matrix#Examples_in_2_dimensions
> [GT0, GT3] is the "geographic" coordinate of the pixel [0, 0] (regardless
> rotation or scaling)
> Cheers
> 21 December 2020 10:24
> Hi all from GDLA.
> Thanks for the opportunity to as a question. It's regarding the Geotransform
> Tutorial (https://gdal.org/tutorials/geotransforms_tut.html). Tried to
> get info in the web but since this seems a tricky one, my searches failed.
> The tutorial only deals with the ideal case of 'North up' images, for
> which GT(2) and GT(4) are zero. However, my images are 'East up' and
> potentially 'any direction up' (underwater photomosaic surveys by ROV). The
> rotation works with '90' for GT(2, 4). But the scaling seems completely
> ignored. Any hint? If it would be easy, I assume your tutorial would give
> an example for how to deal with "non-N-up' images, but ...
> My pics are 1920x1080, with pixel resolution of 0.0015 (yes, 0.15cm per
> pixel, we're flying just 3m above the bottom).
> In case I rotate the images prior to geotransform (in Photoshop),
> geotransform works perfect, with GT(2, 4) = 0. Scaling spot on. I can live
> with that for our last survey but I'm also looking for a solution in case
> our survey heading cannot be 0, 90, 180, or 270, but has to be something
> like 35° (due to bottom currents etc.).
> Best regards, any hint qappreciated,
> Gerhard
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201221/fd1ee5c6/attachment-0001.html>
