[gdal-dev] ogr2ogr question
    matteo
    matteo.ghetta at gmail.com
    Mon Dec 21 22:55:38 PST 2020
Hi Even,
> If you look at the output of
> ogrinfo PG:..... -sql "select ...."
> you'll see that the resulting layer is called "sql_statement", so your ogr2ogr
> invokation will overwrite/create a sql_statement table in your GPKG. You want
> to add -nln intap to rename this SQL result layer.
> And -overwrite deletes and recreates the table from scratch, so if you've
> customized your template with CHECKs, FOREIGN KEYs etc, they will be lost. If
> the target table in the template is empty, you can just use -append instead of
> -overwrite.
go it, thanks! I was sure that if the table names are the same in both
input and output, than ogr2ogr was overwriting the output automatically.
Just for information: -overwrite is doing a "truncate table" before
adding the new features? Is this the reason that FK, CHECKS and other
customization will be lost?
Cheers and thanks
Matteo
