[gdal-dev] Doubts to Convert TopoJson to SHP File
Even Rouault
even.rouault at spatialys.com
Wed Dec 23 08:49:16 PST 2020
On mardi 22 décembre 2020 21:54:44 CET Moises Silva wrote:
> Hi,
> I am newbie to use the GDAL and passing the problem in convert TopoJSON
> to SHP FIle.
> I executed the command below and some files were created (.dbf, .shp,
> .shx) but the file .prj is not created.
> Is there any parameters that I need to pass to create this .prj file?
> ogr2ogr -f "ESRI Shapefile" countries110m countries110m.json
The TopoJSON specification (https://github.com/topojson/topojson-specification
) makes no mention of coordinate reference system. In most cases it might be
EPSG:4326 as suggested by Jukka, as it is the default CRS for GeoJSON from
which TopoJSON "derives"
Even
http://www.spatialys.com
