[gdal-dev] Export multiple tables from GPKG to PG
matteo
matteo.ghetta at gmail.com
Wed Dec 23 23:54:47 PST 2020
Hi Even,
thanks for the reply.
> You could possibly do that in 2 steps:
> - use ogr2vrt to create a VRT from your source GeoPackage and rename layers as
> you wish
> https://github.com/OSGeo/gdal/blob/master/gdal/swig/python/samples/ogr2vrt.py
OK so I've to download this file and run it to build a vrt file (if I
don't want to create it by myself).
> - and then use ogr2ogr to convert that VRT to PG, with -gt unlimited to do
> that in a single transaction
so the parameter is literally ì:
ogr2ogr ...... -gt unlimited
Thanks!
Matteo
