[gdal-dev] gdalwarp: behavior of "mode" resampling with NODATA
Javier Jimenez Shaw
j1 at jimenezshaw.com
Wed Dec 30 03:14:15 PST 2020
What I understand is (2), and also my experience.
Cheers
El mié., 30 dic. 2020 12:11, Jed O. Kaplan <jed.kaplan at arve-research.com>
escribió:
> Working with GDAL 3.0.4
> The behavior of “mode” resampling when NODATA pixels are present is not
> clear to me from reading the documentation. I guess there are two
> possibilities:
> 1) If NODATA is the modal value among the pixels under consideration, then
> the result is NODATA
> or
> 2) The modal value among the pixels under consideration is taken in
> exclusion of NODATA, so that a NODATA will be returned only if ALL of the
> pixels in the resampling window are NODATA.
> I would prefer if it was (2) above, but I would be grateful if anyone
> could confirm how the filter works.
> Many thanks,
> Jed
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201230/d7c2f01d/attachment.html>
