[gdal-dev] NetCDF and EASE-2
    Markus Metz
    markus.metz.giswork at gmail.com
    Sat Feb  1 13:51:57 PST 2020
Regarding this EASE-2 grid (https://nsidc.org/ease/ease-grid-projection-gt),
I found that
On Sat, Feb 1, 2020 at 1:22 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> - the spacing of the lat variable is not constant
the spacing of the lat variable increases drastically towards the poles.
You could convert the netcdf file to xyz text format, then treat it as
vector points and interpolate a grid surface from these points with
appropriate parameters. This should preserve the original values at the
original xy locations and should take care of the increasing spacing of the
lat variable towards the poles. Regarding your use case of snow depth, a
land mask could speed up the interpolation step, skipping oceans.
> I've a somewhat complicated workflow to propose to create a georeferenced
> GeoTIFF file. It assumes you are running GDAL master 3.1.0dev to be able
to
> use the gdalmdimtranslate utility
> 1) Create a tiled geotiff
> gdal_translate NETCDF:"SD_20160901.nc":snd_upd out.tif -co TILED=YES
> 2) Transpose it, and also mirror the values in the x and y directions.
I'm not
> sure why this mirroring is needed at all (at least the one in the
horizontal
> direction. The one in the version direction might perhaps be explained by
a
> north-up vs south-up convention difference between netCDF and GeoTIFF)
> gdalmdimtranslate out.tif out2.tif -co TILED=YES \
>     -array band=1,transpose=[1,0],view=[::-1,::-1]
> (in theory 1. and 2. could be merged in a single step, but doing the
> transposition on the initial netCDF file will be very inefficient. Doing
it on
> a source tiled file is the best)
> 3) Create a out2.tif.aux.xml file with the following content
> <PAMDataset>
>   <Metadata domain="GEOLOCATION">
>     <MDI key="LINE_OFFSET">0</MDI>
>     <MDI key="LINE_STEP">1</MDI>
>     <MDI key="PIXEL_OFFSET">0</MDI>
>     <MDI key="PIXEL_STEP">1</MDI>
>     <MDI key="SRS">EPSG:4326</MDI>
>     <MDI key="X_BAND">1</MDI>
>     <MDI key="X_DATASET">NETCDF:"SD_20160901.nc":lon</MDI>
>     <MDI key="Y_BAND">1</MDI>
>     <MDI key="Y_DATASET">NETCDF:"SD_20160901.nc":lat</MDI>
>   </Metadata>
> </PAMDataset>
> 4) Warp it:
> gdalwarp out2.tif out3.tif -overwrite -co TILED=YES
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200201/d71148bc/attachment.html>
