[gdal-dev] "latest" rasterlite2?
William Kyngesburye
woklist at kyngchaos.com
Sun Feb 2 17:26:00 PST 2020
Hm, well, rasterlite2 1.1.0b0 has been available since June 2018. 1.0 was from 2014, but that didn't have one of the functions at all that is causing trouble, rl2_load_raw_tiles_into_dbms. That was changed in GDAL for a change in the parameters.
About fossil - no rasterlite2, at least not mentioned on the spatialite site. So again, I have no idea where to get the "latest" rasterlite 2 you made the changes in GDAL 3.0.4 for.
I just reverted those changes in my copy of the source and GDAL compiles OK now.
William Kyngesburye
<kyngchaos at kyngchaos.com>
<http://www.kyngchaos.com>
Don't Panic
> On Feb 2, 2020, at 5:12 PM, Even Rouault <even.rouault at spatialys.com> wrote:
> William,
>> I see a change in GDAL 3.0.4 to "fix build against latest librasterlite2".
>> But this breaks compilation for me. The latest ratserlite2 I know is
>> 1.1.0-beta0 from over a year ago.
> Hum, I didn't know this was ever released... When the driver was initially
> developed, it was designed to work with a future version of librasterlite2,
> that wasn't released at that time.
>> Where do I find this new "latest" rasterlite?
> You need to use latest fossil HEAD. Not released yet.
>> Could a test be added to allow for older versions?
> Would be a bit painful... I would have probably not backported this commit
> from master if I had known that 1.1.0-beta0 had been released... Given that
> this rasterlite2 driver is likely a edge case, I'd suggest to just drop the
> driver for now from your compilation. Or you'd have to build latest fossil
> HEAD
> Some instructions at http://www.gaia-gis.it/gaia-sins/about-fossil.html
> (libspatialite to be replaced by librasterlite2)
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
