[gdal-dev] conda conflicts
    Joris Van den Bossche
    jorisvandenbossche at gmail.com
    Wed Feb  5 04:49:15 PST 2020
Hi Laszlo,
The conda packages are not directly controlled by the GDAL developers, so
for the default Anaconda channel, you might want to report an issue at
https://github.com/ContinuumIO/anaconda-issues/issues, and for the
conda-forge package at https://github.com/conda-forge/gdal-feedstock/issues.
If you do that, make sure to provide some more information: the output of conda
info and conda list would help.
Specifically for conda-forge, check here how to set things up to work best
with the conda-forge channel:
https://conda-forge.org/docs/user/introduction.html#how-can-i-install-packages-from-conda-forge
(the strict channel priority is important)
Also, the output you showed below doesn't really show an error. Did you let
the command complete? (it can take a while)
Best,
Joris
On Wed, 5 Feb 2020 at 13:39, László Sándor <sandorl at gmail.com> wrote:
> Hi,
> Many thanks for GDAL. I spent some time on gdal.org, the git repo, the
> Anaconda repo, and even tried a Homebrew installation. I cannot get a
> working installation on my mac.
> As I guess conda was supposed to be the default and foolproof way to get
> started, let me explain how dependencies break.
> Here is how a simple "conda install gdal" proceeds. It did not seem to
> make a difference to activate an environment I use for the Intel Python
> Distro or not, or specify the conda-forge channel or not.
> conda install gdal (*idp*)
> Collecting package metadata (current_repodata.json): done
> Solving environment: failed with initial frozen solve. Retrying with
> flexible solve.
> Solving environment: failed with repodata from current_repodata.json, will
> retry with next repodata source.
> Collecting package metadata (repodata.json): done
> flexible solve.
> Solving environment: -
> Found conflicts! Looking for incompatible packages.
> This can take several minutes.  Press CTRL-C to abort.
> Examining conflict for (and here many packages are repeatedly checked)
> A conda search gdal found the version below, among many:
> gdal                           3.0.2  py37hbe65578_0  pkgs/main
> I was actually hoping to get a simple operation done (below), sorry for
> all this trouble!
> https://gis.stackexchange.com/questions/348598/how-to-use-facebook-geotiff-maps-on-carto/348746?noredirect=1#comment572180_348746
> Thanks for any thoughts,
> Laszlo
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200205/7896ec33/attachment.html>
