[gdal-dev] Cannot set simple geotransform
Even Rouault
even.rouault at spatialys.com
Wed Feb 5 10:31:11 PST 2020
> It's a known bug. There is some analysis at
> https://github.com/mapbox/rasterio/issues/524#issuecomment-156655258.
Actually, is a *past* known bug, at least for the GTiff driver
>From GDAL 2.3.0 news:
* make it accept to write SetGeoTransform([0,1,0,0,0,1]) as a
ModelTransformationTag, and remove particular cases with the [0,1,0,0,0,1]
geotransform (#1683)
This fix also fixes (0,1,0,0,0,-1)
>>> from osgeo import gdal
ds=gdal.GetDriverByName('GTiff').Create('/tmp/test.tif',5,5,1,gdal.GDT_Byte)
>>> ds.GetGeoTransform()
(0.0, 1.0, 0.0, 0.0, 0.0, 1.0)
>>> ds.SetGeoTransform((0,1,0,0,0,-1))
0
>>> del ds
>>> ds=gdal.OpenEx('/tmp/test.tif',gdal.GA_Update)
(0.0, 1.0, 0.0, 0.0, 0.0, -1.0)
http://www.spatialys.com
