[gdal-dev] OGRCreateCoordinateTransformation problem on GDAL	3.0.3 and PROJ 6.3.0
    Even Rouault
    even.rouault at spatialys.com
    Mon Feb 10 02:28:55 PST 2020
On jeudi 23 janvier 2020 18:43:24 CET Even Rouault wrote:
> On jeudi 23 janvier 2020 18:35:40 CET Edzer Pebesma wrote:
> > On 1/23/20 5:58 PM, Even Rouault wrote:
> > >> Thanks! Yes, with SRS->importFromUserInput("EPSG:3857"); etc this works
> > >> fine; I'm OK with the warning, I just don't see how the subsequent
> > >> error
> > >> relates to syntax that is deprecated.
> > > I'm looking at this, but haven't yet an explanation. This is very
> > > subtle,
> > > and seems to be linked specifically to EPSG:3857
> OK, memory helping, I finally identified the root cause. This is a bug in
> PROJ. Fix submitted per https://github.com/OSGeo/PROJ/pull/1873
PROJ 6.3.1 release candidate shipping the fix announced at:
https://lists.osgeo.org/pipermail/proj/2020-February/009360.html
Even
http://www.spatialys.com
