[gdal-dev] Docker images
    Even Rouault
    even.rouault at spatialys.com
    Fri Feb 14 12:50:43 PST 2020
Stéphane,
> - How is the security is managed in those Docker images?
Basically those images are built by a nightly cron job on my machine, and I
don't think I've docker pull'ed the base Ubuntu image in recent times, so they
are probably outdated. Currently you'd better apt update && apt upgrade if you
care about the security patches from the OS provider (not sure what Alpine
does on that respect)
> - How will new versions of distributions be managed?
The usual answer: when someone is keen on updating them, pull requests gladly
accepted, etc etc :-) For the Ubuntu based ones, I guess we should stick on
LTR releases. For Alpine based ones, we can probably be more agressive in
updates and switch to the latest version when it is available.
Even
http://www.spatialys.com
