[gdal-dev] Issue trying to install gdal 3.0.4 on Red Hat 8
Even Rouault even.rouault at spatialys.com
Fri Feb 14 13:37:50 PST 2020
On vendredi 14 février 2020 20:16:47 CET Joseph Risi wrote:
> I'm running Red Hat 8, and I'm trying to install gdal 3.0.4 on it.
> The commands I've excuted thus far:
> wget http://download.osgeo.org/gdal/3.0.4/gdal-3.0.4.tar.gz
> tar zxvf gdal-3.0.4.tar.gz
> cd gdal-3.0.4
> ./configure
> sudo make install
> After I run `sudo make install`, I get the following error messages:
The easiest to fix is (assuming you don't need JPEG 12 bit support):
./configure --without-jpeg12
and "make clean" before rebuilding
http://www.spatialys.com
