[gdal-dev] Occasional ERROR 4 on gdal.Open() with vrt files hosted on AWS S3
Jon Seymour jon at upowr.com.au
Sun Feb 23 23:05:41 PST 2020
On Mon, Feb 24, 2020 at 5:49 PM thomas bonfort <thomas.bonfort at gmail.com>
wrote:
> Jon,
> This issue is probably related to
> https://github.com/OSGeo/gdal/issues/1244 and was fixed in 2.4.4
Thomas,
Thanks very much for that tip, it does sound promising. A thread safety
issue may also explain another symptom I saw once, which was an unexpected
ERROR 1 while parsing the VRT file, however, that has only happened once so
I am not sure if it is the same issue.
Anyway, I will build 2.4.4 and see whether my current workaround (retrying
at most once after calling VSICurlClearCache) is rendered unnecessary.
jon.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200224/4a562abc/attachment.html>
