[gdal-dev] Fedora package status
Sandro Mani
manisandro at gmail.com
Mon Feb 24 02:32:04 PST 2020
> Let me know if I can do anything to help (even if you just want me to
> pester on the bug reports to try to raise the severity of the issues
> around these older package versions!)
I've moved ahead and filed [1] to formally resolve the situation. Feel
free to add comments there.
Sandro
[1] https://pagure.io/fesco/issue/2345
>> Sandro
>> [1] https://copr.fedorainfracloud.org/coprs/smani/gisstack/
>> On 23.02.20 01:45, Nyall Dawson wrote:
>> Hi list,
>> Does anyone with any knowledge of the fedora packaging infrastructure
>> have any advice for getting the gdal library updated in the fedora
>> repos?
>> Even on the most recent Fedora releases, this is stuck at absolutely
>> ancient versions (2.3!).
>> Worse is that the proj library has been updated, resulting in the
>> not-recommended combination of proj 6/gdal 2 (specifically proj 6.2 --
>> a version with known critical bugs).
>> Nyall
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
