[gdal-dev] gdal-dev Digest, Vol 189, Issue 34
Jon Seymour
jon at upowr.com.au
Tue Feb 25 15:31:17 PST 2020
> Jon do you think it could be a memory or storage issue?
Almost certainly not a storage (as in disk or remote s3) issue since the
local disk is not exhausted and there is no evidence of an S3 access issue.
Based on the fact that a call to gdal.VSICurlClearCache appears to clear
the symptom, it does look like a corruption of the in-memory VSICurl cache
(or, more likely, its book-keeping data structures). I suspect Thomas is
correct and the issue will be fixed in gdal-2.4.4 (by the fix for
https://github.com/osGeo/gdal/issues/1244) but it is too early for me to
say for sure yet.
jon.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200226/518f30c5/attachment.html>
