[gdal-dev] Merge and Overviews with VSIMEM
Sean Gillies
sean at mapbox.com
Wed Feb 26 07:27:37 PST 2020
Hi Brenton,
On Wed, Feb 26, 2020 at 7:13 AM Brenton Mallen <brentonmallen1 at gmail.com>
wrote:
> Hi,
> I'm attempting to merge 2 multi-band tiffs as well as build overviews for
> the resulting merged tiff. I'm a bit confused when I attempt to use a
> `vsimem` object to perform the actions in memory. For example, I have a
> couple of functions defined as
> def merge_bands(tiffs, out_file):
> """Merge multi-band GeoTIFFs together.
> Args:
> tiffs (list): List of paths to TIFFs to be merged
> out_file (str): Path to output file
> merge_command = 'gdal_merge.py -separate -o {} '.format(out_file)
> merge_command += ' --config GDAL_CACHEMAX 256'
> merge_command += ' -co compress=LZW'
> merge_command += ' -co TILED=YES'
> for tiff in tiffs:
> merge_command = merge_command + ' {}'.format(tiff)
> sp.check_call(merge_command, shell=True, stdout=sp.PIPE, stderr=sp.PIPE)
> def build_overviews(filename, levels):
> """Build overviews.
> Args:
> filename (str): Input filename
> levels (list): Level (int) or list or levels (ints)
> to build overviews for.
> if not isinstance(levels, list):
> levels = [levels]
> command = 'gdaladdo'
> command += ' -r average'
> command += ' {}'.format(filename)
> command += ' {}'.format(' '.join(str(x) for x in levels))
> sp.check_call(command, shell=True, stdout=sp.PIPE, stderr=sp.PIPE)
> When I attempt to call it, using the following, the `vsimem` object seems
> to no longer be accessible to perform the overview creation:
> merged_mem = '/vsimem/merged.tiff'
> merge_bands(['file1.tiff', 'file2.tiff'], merged_mem)
> build_overviews(merged_mem, [2,4,8,16,32,64])
> I get an `exit status 2` which I believe is due to `merged_mem` being a
> NoneType after the merge is performed.
> I'm also confused about best practices. Ideally, I'd like to do this all
> in the python wrapper but there doesn't seem to be an immediately obvious
> parallel for the `gdal_merge` script.
> I'm using python 3.8 and GDAL 3.0.2.
> Any guidance would be appreciated and thank you for your time,
> Brenton
VSIMEM files are visible within a process (
https://gdal.org/user/virtual_file_systems.html#vsimem-in-memory-files) and
Python's check_call runs your command within a *new* process. You have a
single string named merged_mem, but I think this maps to a different
in-memory file in each of the two processes in your program. Even will have
a more definitive answer, I'm sure. but I think these are your options:
1. use a physical temp file, easily shared between processes
2. use a more sophisticated shared memory (mmap?)
3. implement the merge in Python within the original process
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200226/46a33b56/attachment.html>
