[gdal-dev] Slow GDALComputeRasterMinMax on nc grids
    Even Rouault
    even.rouault at spatialys.com
    Fri Jan  3 11:52:07 PST 2020
On vendredi 3 janvier 2020 14:02:18 CET Jeff McKenna wrote:
> Hi Joaquim,
> I have tested your file on Windows 10 here, with the command:
>     gdalinfo grav_29_img.nc -mm
> which takes about 5 seconds to execute fully.  I am using MS4W 4.0.2
> (GDAL 2.4.3 , NetCDF 4.7.3 )
Jeff,
Do you build netCDF with a custom value of the CHUNK_CACHE_SIZE / chunk-cache-
size setting ?
With the default (4 MB), runtime on my machine is about 7 minutes. But if I
use --with-chunk-cache-size=67108864 as in
https://trac.osgeo.org/gdal/ticket/5291#comment:26 , then it goes down to
9 sec.
So this is a quite old known issue with the netCDF driver with HDF5 chunking &
compression. Due to the netCDF driver exposing rasters with a north origin,
and netCDF Y origin being at south, there's a mismatch between GDAL blocks and
netCDF chunks. So for the sake of simplicity, the netCDF driver exposes one
single line as the GDAL block size. It could/should be improved to make a
better use of netCDF chunks, so as not being too much dependent of the quite
pessimistic default of the netCDF chunk_cache_size.
Even
http://www.spatialys.com
