[gdal-dev] gdal in a web service?
Brad Hards
bradh at frogmouth.net
Mon Jan 6 22:27:28 PST 2020
Lots of WPS implementations can use GDAL – it depends on how much you’re expecting though.
Perhaps pyWPS (https://pywps.readthedocs.io/en/master/wps.html) or GeoServer are worth a look, depending on what languages you are familiar with.
Brad
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Idan Miara
Sent: Tuesday, 7 January 2020 3:25 AM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] gdal in a web service?
Do you know any open source web service that uses GDAL?
I need a web service that, for instance, loads a raster to memory, does some gdal processing (i.e. cropping, warping, dem-coloring etc) and returns the raster to the client to be displayed on cesium, mapbox, etc.
Before I start development I wanted to know if someone has already done something similar.
Kind regards,
Idan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200107/8187c37a/attachment.html>
