[gdal-dev] invalid data in spatial file
Wuyyuru Ravi Teja Krishna
ravitejakrishna.w at zohocorp.com
Wed Jan 15 22:29:30 PST 2020
Hello,
The geojson file before conversion and csv file after conversion are attached below.
the ogr2ogr command line used isĀ
java -cp :gdal.jar -Djava.library.path=libs/ ogr2ogr "-f" "CSV" "-t_srs" "CRS:84" gdaltampered.csv gdaltampered.geojson "-lco" "GEOMETRY=AS_WKT"
thanks.
---- On Thu, 16 Jan 2020 05:44:36 +0530 Even Rouault <even.rouault at spatialys.com> wrote ----
Hello,
> I am trying to convert a geojson file to csv file. but that coordinates were
> tampered i.e 32.76543 is changed as 2333432.76543. Is there a way that
> ogr2ogr conversion util will throw an error for such cases that data is
> invalid. It would be of great help if such error throwing is possible.
You should provide a sample csv file and the exact ogr2ogr command line to
reproduce the issue
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200116/b892980c/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200116/b892980c/attachment.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200116/b892980c/attachment-0001.obj>
