[gdal-dev] GDAL and proj dll name.
Even Rouault
even.rouault at spatialys.com
Wed Jan 22 06:01:32 PST 2020
Hi Tamas,
> However the GDAL build (like for
> https://github.com/OSGeo/gdal/blob/v2.4.4/gdal/ogr/ogrct.cpp) still using
> the default proj.dll name which cannot be configured in the opt file.
It can. You need to define -DPROJ_STATIC for that. -DPROJ_STATIC is a bit
confusing. It didn't mean a static build, but something that was linked at
build time (either a static or dynamic lib), to be opposed at being loaded at
runtime with LoadLibrary(). That's what you want to use.
# PROJ stuff
# Uncomment the following lines to link PROJ library statically. Otherwise
# it will be linked dynamically during runtime.
# To use the new API of proj5 or later, use
#PROJ_FLAGS = -DPROJ_STATIC -DPROJ_VERSION=5
# for proj 4.x:
#PROJ_FLAGS = -DPROJ_STATIC -DPROJ_VERSION=4
#PROJ_INCLUDE = -Id:\projects\proj.4\src
#PROJ_LIBRARY = d:\projects\proj.4\src\proj_i.lib
Even
http://www.spatialys.com
