[gdal-dev] Speeding up gdalwarp process
Simon
twinbirds at protonmail.com
Wed Jan 22 23:07:47 PST 2020
Hi gdal-devs,
I have a question, if there is some way to use gdalwarp in a clustering system (e.g., Sparks) or with GPU to speed up the process? My task involves re-projection and re-sampling of hundreds of high-resolution images. Any ideas to make use of Sparks or GPU is welcomed. Thank you.
Simon
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200123/408d4953/attachment.html>
