[gdal-dev] OGRCreateCoordinateTransformation problem on GDAL 3.0.3 and PROJ 6.3.0
Edzer Pebesma
edzer.pebesma at uni-muenster.de
Thu Jan 23 06:53:46 PST 2020
The combination of GDAL 3.0.3 and PROJ 6.3.0 arriving on debian
platforms is causing some havoc for some spatial R packages. I could
bring one particular problem back to the following C++ program:
#include <stdio.h>
#include "ogrsf_frmts.h"
#include <ogr_spatialref.h>
int main() {
OGRSpatialReference *aSRS = new OGRSpatialReference;
OGRSpatialReference *bSRS = new OGRSpatialReference;
char *pszSRS = NULL, *wkta = NULL, *wktb = NULL;
aSRS->importFromProj4("+init=epsg:4326");
aSRS->exportToPrettyWkt(&wkta);
aSRS->importFromWkt((const char *) wkta);
bSRS->importFromProj4("+init=epsg:3857");
bSRS->exportToPrettyWkt(&wktb);
bSRS->importFromWkt((const char *) wktb);
OGRCoordinateTransformation *ct =
OGRCreateCoordinateTransformation(aSRS, bSRS);
if (ct == NULL) {
printf("ct NULL\n");
exit(1);
exit(0);
which outputs:
Warning 1: +init=epsg:XXXX syntax is deprecated. It might return a CRS
with a non-EPSG compliant axis order.
ERROR 1: PROJ: proj_create_operations: At least one of the operation
lacks a source and/or target CRS
ERROR 6: Cannot find coordinate operations from `GEOGCRS["WGS
84",DATUM["World Geodetic System 1984",ELLIPSOID["WGS
84",6378137,298.257223563,LENGTHUNIT["metre",1]],ID["EPSG",6326]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433],ID["EPSG",8901]],CS[ellipsoidal,2],AXIS["longitude",east,ORDER[1],ANGLEUNIT["degree",0.0174532925199433,ID["EPSG",9122]]],AXIS["latitude",north,ORDER[2],ANGLEUNIT["degree",0.0174532925199433,ID["EPSG",9122]]]]'
to `PROJCRS["WGS 84 / Pseudo-Mercator",BASEGEOGCRS["WGS 84",DATUM["World
84",6378137,298.257223563,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],ID["EPSG",4326]],CONVERSION["unnamed",METHOD["Popular
Visualisation Pseudo Mercator",ID["EPSG",1024]],PARAMETER["Latitude of
natural
origin",0,ANGLEUNIT["degree",0.0174532925199433],ID["EPSG",8801]],PARAMETER["Longitude
of natural
origin",0,ANGLEUNIT["degree",0.0174532925199433],ID["EPSG",8802]],PARAMETER["False
easting",0,LENGTHUNIT["metre",1],ID["EPSG",8806]],PARAMETER["False
northing",0,LENGTHUNIT["metre",1],ID["EPSG",8807]]],CS[Cartesian,2],AXIS["(E)",east,ORDER[1],LENGTHUNIT["metre",1,ID["EPSG",9001]]],AXIS["(N)",north,ORDER[2],LENGTHUNIT["metre",1,ID["EPSG",9001]]]]'
ct NULL
What am I doing wrong?
Edzer Pebesma
Institute for Geoinformatics
Heisenbergstrasse 2, 48151 Muenster, Germany
Phone: +49 251 8333081
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200123/f49841fd/attachment.key>
