[gdal-dev] OGR ExecuteSQL
Even Rouault even.rouault at spatialys.com
Thu Jan 23 10:03:26 PST 2020
On jeudi 23 janvier 2020 12:49:38 CET Andrew Bell wrote:
> Hi,
> This function returns a pointer to a layer.  Does the dataset retain
> ownership of the layer, or does the user need to make sure that the layer
> gets deleted?
https://gdal.org/api/gdaldataset_cpp.html#_CPPv4N11GDALDataset10ExecuteSQLEPKcP11OGRGeometryPKc
Return
    an OGRLayer containing the results of the query. Deallocate with ReleaseResultSet().
http://www.spatialys.com
