[gdal-dev] OGR ExecuteSQL
Mateusz Loskot mateusz at loskot.net
Thu Jan 23 10:21:11 PST 2020
The new docs are searchable
https://gdal.org/search.html?q=ExecuteSQL
Mateusz Loskot, mateusz at loskot.net
(Sent from mobile, may suffer from top-posting)
On Thu, 23 Jan 2020, 18:04 Andrew Bell, <andrew.bell.ia at gmail.com> wrote:
> Thanks.  Just located it in the documentation.  Google was not my friend
> in this case.
> Sorry to bother,
> On Thu, Jan 23, 2020 at 1:03 PM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> On jeudi 23 janvier 2020 12:49:38 CET Andrew Bell wrote:
>> > Hi,
>> > This function returns a pointer to a layer.  Does the dataset retain
>> > ownership of the layer, or does the user need to make sure that the
>> layer
>> > gets deleted?
>> https://gdal.org/api/gdaldataset_cpp.html#_CPPv4N11GDALDataset10ExecuteSQLEPKcP11OGRGeometryPKc
>> Return
>>     an OGRLayer containing the results of the query. Deallocate with
>> ReleaseResultSet().
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
> Andrew Bell
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200123/6c485509/attachment-0001.html>
